Kubota L6060 and New Holland Workmaster 75 comparison questions (not a help me choose/buy thread)
   / Kubota L6060 and New Holland Workmaster 75 comparison questions (not a help me choose/buy thread) #1
johnsayen
None
Hello,
I have an L6060 and I also got to spend a few hours in the seat of a Workmaster 75 with the power shuttle transmission today. I love the L6060 and also enjoyed the Workmaster very much. I like learning as much as I can so I am posting here.
I realize the Workmaster seems to be in a whole different class of tractor based on my experience and I have a few questions:
I noticed that the bucket/loader hydraulics on the Workmaster were much smoother (is that the right word? faster? less "effort"?) than the L6060 - is that because its implement hydraulic flow is 12.6 vs the L6060's 9.4? Or is there a different reason?
I also noticed much better bucket visibility with the New Holland - I presume their loader is longer to give better visibility from the operator seat?
The New Holland has a clutch with a steering column forward/reverse power shuttle lever - I prefer'd the L6060's "clutch-less from the operator's perspective" foot pedal for forward/reverse. A very different experience with regard to rolling after depressing the clutch and driving in general. I imagine many prefer the experience of the new holland. Is someone able to explain the benefits of that style hydrostatic+operator clutch?
Thank you
I also noticed the work master had a quieter cab.
   / Kubota L6060 and New Holland Workmaster 75 comparison questions (not a help me choose/buy thread) #3
I like my WM75. With the power shuttle while I don't have to use the clutch when shifting forward or reverse, I still do. It is a smoother operation. The cab is quiet, I can hear the radio at a reasonable level. The AC blows cold and keeps me cool even in 100 degree Texas sun. I am considering some window tint on the doors and back window just to help out.
   / Kubota L6060 and New Holland Workmaster 75 comparison questions (not a help me choose/buy thread) #4
You're comparing a machine with a hydraulic clutch (WM75) to a hydrostatic transmission (L6069) The WM's power from the engine is delivered through the clutch to the gears and wheels. A hydrostat drives a pump that drives a hydraulic motor that then goes to the gears and wheels. The hydostat pump/motor has a power limit and greater energy loss than a clutch.
That makes sense. Thank you.
   / Kubota L6060 and New Holland Workmaster 75 comparison questions (not a help me choose/buy thread) #6
Different class tractor. L6060 is a compact utility and the Workmaster is a utility. That means different frame size. Workmaster has 12 x 12 shuttle transmissions so you need to shift gears to match speed, especially PTO work where the ag equipment for which the Workmaster is intended is 540 rpm. The L6060 has 3 speed ranges but goes zero to max infinitely in each range. The tractors are intended for two different customers but crossover happens. For example, I use my L6060 for baling small squares, a job better suited for a Workmaster but my dealer won’t trade even up. I got the L6060 4 years before I got my SVL75-2. Now I use the CTL for most of the jobs the L6060 did. But it doesn’t have a drawbar or PTO. I would love the quieter cab and smoother ride of the Workmaster, but my dealer only thinks of his profit, not my creature comfort.
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2017 Ford F550 Chassis (A55973)
2017 Ford F550...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
