Husqvarna LGT 24K54 - seat change, wont run when I disengage brake
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #11
The newer Kioti's do now as well. Butt in seat, neutral, and brake pressed.
That was the reason I said most, because I was sure I was missing some brand that I don't work on enough to keep up with the changes.
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #12
Thinking most, if not all, are heading that way for the more popular smaller tractors.
Yep you need to disable that switch.
Thanks. Weird that that's the "answer". I wonder what the difference is on the wiring harness of the TS 348D and my LGT 24K54... I couldn't find it in the wiring diagrams. (At least she's running now).
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #14
You mentioned that the switch won't physically fit. If one seat the round disc type and the other not, the cap unsnaps and you can change the switch out. If one has the lovely smart ignition switch system, I know the seat switches look the same, but are different. I have the other number that will work in that case. If you can come up with the full product number on both, we can probably figure it out.
I'll give that a try and if it doesn't work, will share more details. Thanks Tomplum
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
434669 (A48836)
434669 (A48836)
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
John Deere 310K Backhoe (A51573)
John Deere 310K...
