Husqvarna LGT 24K54 - seat change, wont run when I disengage brake
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #11
The newer Kioti's do now as well. Butt in seat, neutral, and brake pressed.
That was the reason I said most, because I was sure I was missing some brand that I don't work on enough to keep up with the changes.
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #12
Thinking most, if not all, are heading that way for the more popular smaller tractors.
Yep you need to disable that switch.
Thanks. Weird that that's the "answer". I wonder what the difference is on the wiring harness of the TS 348D and my LGT 24K54... I couldn't find it in the wiring diagrams. (At least she's running now).
   / Husqvarna LGT 24K54 - seat change, wont run when I disengage brake #14
You mentioned that the switch won't physically fit. If one seat the round disc type and the other not, the cap unsnaps and you can change the switch out. If one has the lovely smart ignition switch system, I know the seat switches look the same, but are different. I have the other number that will work in that case. If you can come up with the full product number on both, we can probably figure it out.
I'll give that a try and if it doesn't work, will share more details. Thanks Tomplum
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
