Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #18,382
That's looking a little funky, did you get some good stuff out of it?
They were HUGE (by black walnut standards) logs, about 30"+ diameter. The tree had been dead a while when I saved it from the dump so the outsides are a little soft. But yes there is plenty of good wood left. Probably not gonna make any cabinets out of it, but I see many nice cutting boards coming from it.
   / Tractors and wood! Show your pics #18,383
Looks like you are getting real good with the grapple! Interesting tires on the Kioti. Nice.
Thanks @goeduck , those are the R14 tires which are fairly new. Sort of a crossover between R1 and R4, thus R14 but also turf friendly. I believe the construction to be similar to the R4 for sidewall strength. I had R1 tires on my old tractor, was originally going to go with R4 for this one. Decided to give these a try. So far they are working out pretty well.
   / Tractors and wood! Show your pics #18,384
Yeah, my saw is more manual than yours.
And I like the fact my jack is wider more stable than a car jack and has the provision to bolt it down.
I'll watch the neighbors for crappy old flower box cars and see if I can scoop a jack of some kind.
I could even mount a plate across the top for stability.
I'm even visualizing a sort of rack that will allow it to be suspended between the rails of the deck and movable as needed.
Maybe over-engineering too.
I think I have a 6 ton bottle jack somewhere that was left behind by a tractor trailer tire repair guy (never bothered to
come back for it). It's kind of a heavy bugger, but free at the moment.
Thanks for the tips everyone.
   / Tractors and wood! Show your pics #18,385
The bottle jack seems like it would be unstable holding up one end of a log...
   / Tractors and wood! Show your pics #18,386
Be careful playing with jacks and timber or logs make sure it has a good contact area like a falling jack does as well as a swivel style head.
   / Tractors and wood! Show your pics #18,389
Interesting. I have not seen those before. Are yours radials?
   / Tractors and wood! Show your pics #18,390
I'm not really certain but am inclined to think they are not radials. They do say they are low sidewall tires but I/m not really seeing the word "radial" anywhere. Hard to find any hard specs but here is how they are being marketed.
Moving conversation to:
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A55758)
2 windsor 351...
2017 FORD F550 XL SERVICE TRUCK (A51406)
2017 FORD F550 XL...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2002 LEEBOY L7000T ASPHALT PAVER (A52705)
2002 LEEBOY L7000T...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
