Need Advice - Shibaura S773L Rebuild
   / Need Advice - Shibaura S773L Rebuild #1
cgsmiley
New Holland T1030
I'm doing a complete rebuild of the engine for my New Holland T1030. The engine is a Shibaura S773L. The block is cracked in several places and also has a hole in it (threw a rod), so I'm replacing the entire block. I'm not a diesel mechanic by any means but I am willing to tinker and learn. I was able to find a used, but good condition, block. That being said, the original engine from my tractor is an S773L M662 whereas the used block I acquired is an S773L M661. As far as I can tell there is only one minor difference. The M662 has a small gear that is located next to the Cam Gear. The M661 block does not have a place for this gear. Also--I can't figure out what that gear does. It doesn't seem to engage or turn any other parts but I know I could be mistaken. The attached pictures show the gear in question and the difference in blocks. Anyone out there have any idea what this gear does? What are the chances I could rebuild the engine in M661 block, without this gear, and not have any major issues? Otherwise, I suppose I could have the block machined to receive the gear...right?
Thanks!
   / Need Advice - Shibaura S773L Rebuild #2
Maybe for the Tach on a older version of the motor ?
   / Need Advice - Shibaura S773L Rebuild #4
I have workshop manual for S773L. Several but not all illustrations of the block show the hole, but I find nothing in there that hints what it or the gear is for.
btw my S773L is in a Case/IH, a big wheeled version of the NH 1030. PM me if I can help with specs, measurements, timing, etc.
Thanks. I'll reach out if I need anything. I also have a manual for my tractor and engine so I do have some good reference material. That gear, however, seems to be a mystery for now.......
   / Need Advice - Shibaura S773L Rebuild #7
I was busy debugging an electrical issue on mine Sat & missed what stevem5215 said. (y) There isn't room for much between the injector & hydraulic pumps but maybe a cable. Gear isn't supported on both ends so doesn't see much load. Newer models drive the tach electrically from the alternator. If I didn't need the gear or hole I might install a brass (marine) welch plug flush from the back with a dab of Teflon pipe dope or Permatex #2 and stake it in.
2014 Ford Explorer AWD SUV (A55758)
2014 Ford Explorer...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
