Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #18,664
I dragged the log splitter out a couple weeks ago, and like always that Honda motor fired right up first pull after sitting a year. However it ran about 10 seconds then died. I walked back over & it started first pull, but ran rough, then popped a few times, then died. I guess it was finally time for some engine maintenance. Drained off some gas, there was a little water in it, thought that must have been it, and put it back together. started first pull ran 10 seconds and died. So I repeated process, but added some dry gas/fuel treatment. Started, then same thing died after 10 seconds. So this time I completely tore down carb, really clean inside, but I checked every hole, needle, surface, nook, & cranny in there anyway. I then drained all the gas, no water but added fresh non-ethanol anyway. Reassembled, and started first pull, ran 10 secs. & died. Only 1 thing left to change. Of course this was now Sunday afternoon, so even if Napa had a plug for this, they were closed anyway. Got plug a couple days later but it was the following weekend before I could get back to it, sure enough, changed plug and she runs like a champ again. Sorry, no tractors, & no pics to accompany the story, but I would think if your reading this thread, you likely already know what a spark plug looks like! Just sharing a story and a recommendation, if you can find non-ethanol gas, use it in your small equipment, Carb was super clean, after 4 years of use and sitting all those summers, so worth it.
   / Tractors and wood! Show your pics #18,666
I was thinking vent in gas tank cap clogged but spark plug would have been a better first choice. Good story Loader man.
gg
   / Tractors and wood! Show your pics #18,668
Hah, I was thinking fuel filter...(y)
Trickle flow fills bowl, 10 sec runs out the bowl.
I was thinking the exact same thing..
   / Tractors and wood! Show your pics #18,669
I did leave out a few steps, but on one of the stalls, I quickly opened the screw at the bottom of bowl and had good flow out of the drain. But I couldn't give every detail , you all would've have solved it halfway through....
   / Tractors and wood! Show your pics #18,670
Some oldies, back when I was doing ~6 cord a year between 2 wood stoves. Now we have a OWB and a newer tractor with a winch, just drag the logs to the boiler cut and toss em in. Last year was roughly 16 cord
So you went from burning 6 cords a year in two wood stoves to 16 cords a year in your OWB? Were you also using some other source of heat when you had the wood stoves, or is the OWB just that much less efficient?
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
Portable Restroom (A54865)
Portable Restroom...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
16FT box truck (A53422)
16FT box truck...
