2007 Toolcat - no traction, stiff suspension, differential lock?
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #1
Mudninja
Member
Bobcat Toolcat 5600
I recently purchased a used Toolcat. A 2007 5600. Always thought they looked very handy and wanted one. Found one that was extremely rusty but at a good price. I've set out restoring it. One thing that has surprised me is how little traction the machine has. It gets stuck at even the slightest spot where the plane it is driving on becomes not flat. Reading more info, I hear that this is a common finding with the toolcat. Was hoping it would be more like my skid steer. Questions I have for others that have them (as I don't even have another in my area to compare it to):
  • The front a-arms have zero movement. The a arms rest on the rubber bushings all the time. When loaded, unloaded and even when I have lifted the entire machine off the ground on a lift. Is that normal? The rear a-arms have a good amount of travel. It's like the front is just for looks and is really a solid assembly.
  • The moment the machine encounters any type of uneven ground, one of the wheels comes off the ground in front and rear (caddy corner). At that point it obviouslly stops and spins. I see nothing on this machine that provides the option to lock the differential. As such, the wheel with the least resistance (the one off the ground) spins and the one on the ground just sets there. I have discovered that if I get a run at it, I can overcome the issue in some cases by getting through it before the momentum stops. I've read posts on this forum where there is a rear differential lock. Wondering if that was an option that my machine did not come with spec'd out.
  • The whole lack of a diff lock is so frustrating, I've reviewed the service manual and am contemplating welding the rear dif solid. Has anyone ever done that or added a lock to a tool cat? At that point it should behave like my Polaris RZR. I drive it mostly in areas where I am not worried about disturbing the soil, so it shouldn't cause an issue from that perspective.
  • It is also worth noting that the dump bed is being remade. The other one was so rusty it self destructed the first time I used it. Hoping that additional weight will help the traction matters some.
Appreciate the time and hoping to share some ideas. Thanks.
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #2
I have no experience with the D Series, but would think that it should move just like the F Series does.
Raised the front wheels off the ground:
A arms are hanging down:
And compress the rubber with weight in the bucket:
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #3
Maybe the rubber snubbers get old and stiff. If they do, you would lose your limited wheel articulation.
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #4
regardless of the rubber block when the machine is lifted up the arms should allow the axle to drop, something is preventing the arms moving, when no load is on the front the rubber bumpers should not be touching, my current machine has traction control my old one had rear axle lock, its setup always had one front and rear powered so something is not working on yours
Appreciate the help everyone. The photo above with the a-arms gapped below the rubber bushing when up in the air is just what I needed to see. Mine do not drop. Something must be froze up in the shock or a-arms I am betting. Will have to dig in and will let you know what I find out.
Laurencen, I do get one front and one rear going but that is a much as it will do. I will need to investigate why the rear axle lock isn't working. From the service manual, I can't see anything that goes to the rear differential that would actuate it. There is a "brake" hydraulic hose that runs to it to engage the brake, but that is all.
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #6
on my older machine it had a doff lock switch on the middle console, what I found it only worked when the steering was in 2 wheel and the wheels were straight and light lit on console, also only in low speed not high range,
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #7
If you weld your diff you won't be able to steer that axle (well you CAN but it won't work well).
I think it would behave much like my Polaris RZR. It has a solid rear axle (no dif). When you turn it tears the heck out of what ever is under it. Where I live, this isn't an issue. Am I missing something that would prevent the rear steering from actually steering with the welded dif? I think it would still steer, just scrub the tires as it turns as they would both be turning at the same revolutions.
Thank you. Unfortunately, I see no diff lock switch on the middle console. I've read about the 2 wheel steering and rear wheels straight requirement. One thing for certain, my rear wheel sensor needs some attention. I never have gotten the little green light to come on indicating the rear wheels are straight. I have to look outside and verify for myself. This may be my problem. With that said, however, I still do not see anything in the service manual for the rear differential that has anything to do with a locker. Only thing running to it is the brake hose.
   / 2007 Toolcat - no traction, stiff suspension, differential lock? #10
The only use I know of a welded/locked steered axle in a high mu use case is FWD road racing. They get the benefit of traction (some understeer penalty on turn in) for corner exit but they will note how teribble the car is in the paddock at low speed if they try to turn sharp at all (typically less than 90deg steering wheel angle, 1/3? max steer). This not only cause the tires to skip/hop but it also loads up the driveline. If you are going to be on a very soft/low mu surface then it will probably work out ok but if you drive pavement and expect to do steering on that axle I don't think it will work out well. However, if you do it please video it cause I'm interested to see! Note that with 4WS the % difference of inside to outside tire "ideal radius" is bigger than in 2WS and thus will cause more binding.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2016 John Deer 5075E (A60462)
2016 John Deer...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
