Hydraulics 101 for my Mini Backhoe Build
   / Hydraulics 101 for my Mini Backhoe Build #51
Norm,
typically there is no fix to spool leakage unless the spool is not being spring centered correctly. The spool slides in the mating bore in the cast valve housing the clearance between spool and bore along with amount of overlap of spool lands on the casting lands is what determines leakage. Roundness of both items is also a factor.
Do not install 600 PSI rated valves in a 3000 PSI system. Some function will have them at pressure higher than 600 and then you will have a blown apart valve.
Norm,
oldnslo, the reason I'm considering the 600 PSI rated valve is because #1 - that rating is well below what it will actually stand. #2 - the brass construction of said valve may well be stronger than the cast street elbows I've been using on the same cylinders. If that is the case then I should probably be changing those out for steel elbows rated for hydraulic?
CATERPILLAR 535C SKIDDER (A52707)
CATERPILLAR 535C...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A56129)
2007 POWERSCREEN...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
