/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,091
Why not mulch some of the leaves?
I use the blower to get the edges and driveways, but use the lawn tractor to mulch as much as possible.
Same thing here. I generally don't pick them up, I mulch them with a mulch kit on the mower. When the lawn gets too thick with chopped leaves, like under trees, I blow some of that around to less thickly dispersed areas, and onto flower beds.
Mulching some leaves into the lawn is good for it, but I do think with the amount I mulch into the lawn by fall's end, I'm choking it a bit. And it certainly doesn't leave the lawn looking as nice as Irving's.
Yesterday I took my dethatcher out back, did a bunch of that...wow I pulled up a lot! So today I'm gonna bust out the pull-behind sweeper, pick all that up along with some leaves.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,092
Had a busy day yesterday, boys! Dethatched around the pond, swept all that up, put together and mounted the ballast box I just got, jacked up the new mower, cleaned out deck and changed to mulching blades (which was a bear to do, it SUCKED!).
PXL_20211018_212508351.jpgPXL_20211018_223137563.jpgPXL_20211019_201628169.jpgPXL_20211019_212012708.jpgPXL_20211019_214427576.jpgPXL_20211019_230243967.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,093
I think it would be better for the lawn, it leaves fertilizer behind for the following year. The leaves get so thick on my lawn it would overwhelm the mulcher.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,094
Ordered replacement tie rods at $140ea for my front end and installed today.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,095
Any idea why there's oil under here and around? The front end was down fluid a bit but I haven't seen any puddles where it's leaking.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,096
It could be seeping from the pivot seal, I had to replace mine last year, wasnt too bad of a job.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,097
Ya, I thought that too, from that gasket but it looked like a tough job. Hopefully not.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,098
When did you do the axle fluid change, recently? Maybe that's just leftover from then?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,099
Nah, I changed that out 2 yrs and 150 hrs ago but I'm changing it anyways.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,100
Gotcha. Well we'll be watching you mess with it, whatever it is. Hopefully no biggie.
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
16FT box truck (A53424)
16FT box truck...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2007 Ford E-450 Super Duty 16ft Portable Command Center Office Truck (A55852)
2007 Ford E-450...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
