/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,091
Why not mulch some of the leaves?
I use the blower to get the edges and driveways, but use the lawn tractor to mulch as much as possible.
Same thing here. I generally don't pick them up, I mulch them with a mulch kit on the mower. When the lawn gets too thick with chopped leaves, like under trees, I blow some of that around to less thickly dispersed areas, and onto flower beds.
Mulching some leaves into the lawn is good for it, but I do think with the amount I mulch into the lawn by fall's end, I'm choking it a bit. And it certainly doesn't leave the lawn looking as nice as Irving's.
Yesterday I took my dethatcher out back, did a bunch of that...wow I pulled up a lot! So today I'm gonna bust out the pull-behind sweeper, pick all that up along with some leaves.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,092
Had a busy day yesterday, boys! Dethatched around the pond, swept all that up, put together and mounted the ballast box I just got, jacked up the new mower, cleaned out deck and changed to mulching blades (which was a bear to do, it SUCKED!).
PXL_20211018_212508351.jpgPXL_20211018_223137563.jpgPXL_20211019_201628169.jpgPXL_20211019_212012708.jpgPXL_20211019_214427576.jpgPXL_20211019_230243967.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,093
I think it would be better for the lawn, it leaves fertilizer behind for the following year. The leaves get so thick on my lawn it would overwhelm the mulcher.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,094
Ordered replacement tie rods at $140ea for my front end and installed today.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,095
Any idea why there's oil under here and around? The front end was down fluid a bit but I haven't seen any puddles where it's leaking.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,096
It could be seeping from the pivot seal, I had to replace mine last year, wasnt too bad of a job.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,097
Ya, I thought that too, from that gasket but it looked like a tough job. Hopefully not.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,098
When did you do the axle fluid change, recently? Maybe that's just leftover from then?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,099
Nah, I changed that out 2 yrs and 150 hrs ago but I'm changing it anyways.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,100
Gotcha. Well we'll be watching you mess with it, whatever it is. Hopefully no biggie.
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2002 Toyota Rav4 (A56859)
2002 Toyota Rav4...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
2014 Chevrolet Tahoe SUV (A55973)
2014 Chevrolet...
