Fuel in oil sump (a lot of fuel)
   / Fuel in oil sump (a lot of fuel) #1
Vernth64
JD 4024 Doosan compressor
I have a Doosan compressor powered by a JD 4024 with only 1900 hrs. On a test run, the sump filled with fuel up to the dip stick. I was wondering what could be causing this to happen.
   / Fuel in oil sump (a lot of fuel) #3
On that engine there are 4 individual fuel pumps built into the engine, one for each cylinder and they are operated off cam shaft. They are a SOB to replace and are supposed to be done in sets. I don't know how you would test to know which one would be the culprit.
Here is a video showing a little bit of it.
4024 Fuel Pump
   / Fuel in oil sump (a lot of fuel) #4
Well, if it’s leaking that bad..
U could remove the steel line and put an air hose to the pump and injectors and listen for a hiss..
Just a thought..
   / Fuel in oil sump (a lot of fuel) #5
Just a thought..
You've seen more pumps than most. What's your opinion on the JD 4024 repair?
   / Fuel in oil sump (a lot of fuel) #6
Very expensive to repair..
The fuel system WILL NOT TOLERATE ANY WATER what so ever..
   / Fuel in oil sump (a lot of fuel) #7
Not sure what to make of that. The OP has fuel in the sump; no mention of water anywhere.
rScotty
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
200387 (A51247)
200387 (A51247)
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
