Fuel in oil sump (a lot of fuel)
   / Fuel in oil sump (a lot of fuel) #1
Vernth64
JD 4024 Doosan compressor
I have a Doosan compressor powered by a JD 4024 with only 1900 hrs. On a test run, the sump filled with fuel up to the dip stick. I was wondering what could be causing this to happen.
   / Fuel in oil sump (a lot of fuel) #3
On that engine there are 4 individual fuel pumps built into the engine, one for each cylinder and they are operated off cam shaft. They are a SOB to replace and are supposed to be done in sets. I don't know how you would test to know which one would be the culprit.
Here is a video showing a little bit of it.
4024 Fuel Pump
   / Fuel in oil sump (a lot of fuel) #4
Well, if it’s leaking that bad..
U could remove the steel line and put an air hose to the pump and injectors and listen for a hiss..
Just a thought..
   / Fuel in oil sump (a lot of fuel) #5
Just a thought..
You've seen more pumps than most. What's your opinion on the JD 4024 repair?
   / Fuel in oil sump (a lot of fuel) #6
Very expensive to repair..
The fuel system WILL NOT TOLERATE ANY WATER what so ever..
   / Fuel in oil sump (a lot of fuel) #7
Not sure what to make of that. The OP has fuel in the sump; no mention of water anywhere.
rScotty
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
7046 (A50322)
7046 (A50322)
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
