Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,051
^^^ Maple? That’s a nice looking stick of firewood.
   / Tractors and wood! Show your pics #19,052
What a shame to make firewood out of it!
   / Tractors and wood! Show your pics #19,054
I used to haul any decent logs to the sawmill but the local mill closed last year and it’s not worth the effort to truck them to a different one.
   / Tractors and wood! Show your pics #19,055
Well get you a little mill then...
   / Tractors and wood! Show your pics #19,056
I’d say this log is around a ton. Here’s as far as I could hold it over the side without tipping. View attachment 719347
Those little things are pretty strong. I would want one to lift something like this. Around 1700-1800 lbs
   / Tractors and wood! Show your pics #19,057
We got a ton of rain over the weekend so I've kept my tractor out of the woods for a couple days. Instead I did some boundary line maintenance. I like to keep the lines well marked and clear enough to walk. I put my saw in an old back pack and take a hike until I find a place that needs work. The uphill side is ours.
gg
   / Tractors and wood! Show your pics #19,058
I tried to lift the trailer I had my cut lumber on, to move it to a difficult spot we couldn't do with the truck.
Flattened the front tires (not blown, just flattened) and almost impossible to steer.
I think it may have been too heavy :)
Got it moved but it was stressful waiting for a tire or hose to pop.
It was tough to pull with the 3/4 ton Ford as well.
   / Tractors and wood! Show your pics #19,059
What air pressure do you keep in those front tires?
   / Tractors and wood! Show your pics #19,060
Still original Chinese tires so metric, but...
160 KPa = 23psi front
120 KPa = 17.5psi rear
I pumped them up before use because they were low from sitting.
That trailer was plain 'ol heavy. It was chucking the truck around getting it here.
Back roads. Took it easy.
2019 International DuraStar 4300 24FT Box Truck (A55788)
2019 International...
UNUSED XSTAR 250 GALLON FUEL TANK (A54756)
UNUSED XSTAR 250...
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2014 BMW X1 (A55758)
