Husqvarna ZTH6127 mower with Kohler Command Pro 27hp
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #1
Bl8tant
West Virginia
Satoh S-650G
The machine: 2004 Husqvarna ZTH6127 commercial zero-turn mower with Kohler Command Pro 27hp vertical shaft engine
I figure lots of guys here have seen nearly every mower made. So maybe you can help me here. My engine tag is missing.
I need the Model ,Spec, etc. numbers for the Kohler Command Pro 27hp (vertical shaft) engine on my mower. If you have or know anyone with the same mower I would really appreciate it if someone could post the numbers.
I called Husqvarna and they were NO help. Local dealer said they could not help without the numbers from the engine :confused2:.
My neighbor has 2 of these mowers and I own one also (just bought mine used) and all made the same year. Unfortunately, all three have had their engine tags "pressure-washed" away. I love Kohler motors, but I hate that cheesy sticker they use. Briggs and their stamped numbers are the way to go. :grin:
Thanks!
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #2
I'm having the exact same m e problem. Need engine I.D. number, ect...
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #3
Post 1) A pic of the engine 2) Product number complete off the machine tag 3) Anything in particular you need the number for at this juncture? 4) Welcome to TBN!
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #5
Pretty sure it’s a kohler command pro CH750
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #7
With the post being from 2013, a follow up from a flash in the pan in October- my guess is small block Chev.
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #9
It would be a CV not CH since it is vertical shaft.
I would "guess" CV740. I have a CH740 that is a horizontal shaft 27 hp Kohler Command Pro.
Yes, thats what i meant. 🤦‍♂️
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
199049 (A51243)
199049 (A51243)
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
2000 International 4700 26FT Box Truck (A51692)
2000 International...
