Husqvarna ZTH6127 mower with Kohler Command Pro 27hp
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #1
Bl8tant
West Virginia
Satoh S-650G
The machine: 2004 Husqvarna ZTH6127 commercial zero-turn mower with Kohler Command Pro 27hp vertical shaft engine
I figure lots of guys here have seen nearly every mower made. So maybe you can help me here. My engine tag is missing.
I need the Model ,Spec, etc. numbers for the Kohler Command Pro 27hp (vertical shaft) engine on my mower. If you have or know anyone with the same mower I would really appreciate it if someone could post the numbers.
I called Husqvarna and they were NO help. Local dealer said they could not help without the numbers from the engine :confused2:.
My neighbor has 2 of these mowers and I own one also (just bought mine used) and all made the same year. Unfortunately, all three have had their engine tags "pressure-washed" away. I love Kohler motors, but I hate that cheesy sticker they use. Briggs and their stamped numbers are the way to go. :grin:
Thanks!
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #2
I'm having the exact same m e problem. Need engine I.D. number, ect...
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #3
Post 1) A pic of the engine 2) Product number complete off the machine tag 3) Anything in particular you need the number for at this juncture? 4) Welcome to TBN!
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #5
Pretty sure it’s a kohler command pro CH750
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #7
With the post being from 2013, a follow up from a flash in the pan in October- my guess is small block Chev.
   / Husqvarna ZTH6127 mower with Kohler Command Pro 27hp #9
It would be a CV not CH since it is vertical shaft.
I would "guess" CV740. I have a CH740 that is a horizontal shaft 27 hp Kohler Command Pro.
Yes, thats what i meant. 🤦‍♂️
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
