Napa Gold 1334 oil filters have changed....
   / Napa Gold 1334 oil filters have changed.... #1
Sean2202
CT
Kubota L305DT
Anyone notice that Napa Gold oil filter 1334 oil filter has changed recently? Maybe a new supplier? I have not cut open a new style filter yet. For starters the box is sealed different. The box states "contents made in South Korea." The "old style" Napa gold states "Made in USA". The new filter sealing gasket is different and has 6 holes on top while the USA made old style has 8 holes on top. The new filter has a sealed plastic top while the old style did not come with that. The old-style filter is slightly longer as well.
Sean
   / Napa Gold 1334 oil filters have changed.... #2
Iirc, a 1064 had less holes and was taller compared to a 1334 just like your pic shows.
Maybe wix 'consolidating' filters??
Both work on the 790 and the Hyundai Santa fe we use to own...
   / Napa Gold 1334 oil filters have changed.... #3
A parts store rep told me Wix has been purchased by Mann filters.
Mann stuff always looked top-notch.
   / Napa Gold 1334 oil filters have changed.... #4
If I recall Correctly, Mann is just a "Lable", They don't make all that they sell.
I was sad when finding out that the NAPA Gold were no longer WIX.
   / Napa Gold 1334 oil filters have changed.... #5
I hope whoever makes the Napa Gold filters now does a better job than the last manufacturer. Saw this video where they cut open a Kubota branded oil filter vs Napa Gold, Platinum and Silver filters.
   / Napa Gold 1334 oil filters have changed.... #7
After some 50 years doing mechanical things, I am still mystified why people go for aftermarket rather than OEM filters.
rScotty
Because some after market filters are as good as OEM and considerably less expensive due to extra high mark up.
   / Napa Gold 1334 oil filters have changed.... #8
Not too long ago, I saw a Kubota oil filter with a split can, I've never seen that on a NAPA Gold, and I've used a bazillion of them!
The other day I bought a Kubota oil filter for one of my tractors, it was waaaay shorter than the original filter, I actually thought the dealer made a mistake but nope, the longer one has been replaced with a shorter one!
SR
   / Napa Gold 1334 oil filters have changed.... #9
All you have to do is figure out which ones are as good and which ones aren't. Here's a hint: looking at them isn't the answer.
Are you prepared to go toe to toe with a machine manufacturer to prove the Brand X filter you saved $10 on is as good as theirs and didn't cause a $6000 fuel system repair?
   / Napa Gold 1334 oil filters have changed.... #10
@ Sawyer Rob I wonder if Kubota has gone through their entire filter line like that. Did you run the number online with your original?
Box Truck Hydraulic Tuck-Away Lift Gate (A52377)
Box Truck...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
2008 Caterpillar 303.5C Mini Excavator (A52377)
2008 Caterpillar...
