Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,441
Question on the hole you cut for the jack. I understand how to cut the front, back, top and bottom.. but then how do you get the block of wood out? just bash it with a maul or something?
   / Tractors and wood! Show your pics #19,442
They meet in the center so the block will be loose one trick is to bore in again for a little larger kerf, use your axe with the cutting edge to stick into the block, or you can use wedges to get them out. If the double rams are going in the seat is done differently but it’s roughly the same idea.
   / Tractors and wood! Show your pics #19,443
so then it is a "pie wedge" cut into the tree, yes?
   / Tractors and wood! Show your pics #19,444
Not always sometimes it’s a block it really depends on the situation and what the tree needs.
   / Tractors and wood! Show your pics #19,445
I cut some fire wood this morning. Here's a beech afflicted with beech bark disease.
It was about 30* with wet flurries that made the snow stick to everything. I added a second log to the hitch as I went up the trail. Kept going like that
Until pulling into the landing and dropping the hitch.
Bucked it up into 20 something foot pieces and added it to the pile.
gg
   / Tractors and wood! Show your pics #19,447
That's some nice hemlock Eric and you have what seems to me a perfect reason to cut it !
gg
   / Tractors and wood! Show your pics #19,448
If you had nothing to burn except beech that size your winters would stay warm. 👍
That's the sized wood I like to cut. Easy to handle and while I do have a splitter it also splits nicely with a maul.
   / Tractors and wood! Show your pics #19,449
   / Tractors and wood! Show your pics #19,450
20pc 4ft. x 3ft. Black Metal Diamond Plate (A55758)
20pc 4ft. x 3ft...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2005 Ford Explorer 4X4 SUV (A55758)
2005 Ford Explorer...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
