Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,441
Question on the hole you cut for the jack. I understand how to cut the front, back, top and bottom.. but then how do you get the block of wood out? just bash it with a maul or something?
   / Tractors and wood! Show your pics #19,442
They meet in the center so the block will be loose one trick is to bore in again for a little larger kerf, use your axe with the cutting edge to stick into the block, or you can use wedges to get them out. If the double rams are going in the seat is done differently but it’s roughly the same idea.
   / Tractors and wood! Show your pics #19,443
so then it is a "pie wedge" cut into the tree, yes?
   / Tractors and wood! Show your pics #19,444
Not always sometimes it’s a block it really depends on the situation and what the tree needs.
   / Tractors and wood! Show your pics #19,445
I cut some fire wood this morning. Here's a beech afflicted with beech bark disease.
It was about 30* with wet flurries that made the snow stick to everything. I added a second log to the hitch as I went up the trail. Kept going like that
Until pulling into the landing and dropping the hitch.
Bucked it up into 20 something foot pieces and added it to the pile.
gg
   / Tractors and wood! Show your pics #19,447
That's some nice hemlock Eric and you have what seems to me a perfect reason to cut it !
gg
   / Tractors and wood! Show your pics #19,448
If you had nothing to burn except beech that size your winters would stay warm. 👍
That's the sized wood I like to cut. Easy to handle and while I do have a splitter it also splits nicely with a maul.
   / Tractors and wood! Show your pics #19,449
   / Tractors and wood! Show your pics #19,450
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
(75) 2" X 2" X 8' ANGLE IRON (A54756)
(75) 2" X 2" X 8'...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
RHINO 160 - 5' ROTARY MOWER, 3PT (A54756)
RHINO 160 - 5'...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
