Where Do You Get Your Points and Condensers From?
   / Where Do You Get Your Points and Condensers From? #1
Ledgemere Farm
Limerick, Maine
A bunch
The quality seems to be hit or miss these days. Steiner has a good quality starter switch, just wondering where the masses shop?
   / Where Do You Get Your Points and Condensers From? #2
I'd be seeking Blue Streak or Echlin. But any are a crapshoot. The best condensers are the ones still working in distributors or ones in a drawer that were taken out of service "because". When I was still wrenching on tractors I got in the habit of NOT changing condensers in running engines.
My super c still has an IH cap, rotor and condenser in it. I rue the day they d
   / Where Do You Get Your Points and Condensers From? #4
I'd replace with electronic. Did it on our 1969 Alfa. Otherwise, it burnt points in a couple thousand miles because the contacts would never line up. Put in a Hall system back then.
   / Where Do You Get Your Points and Condensers From? #5
X2 on replacing with electronic, a good choice is Pertronix.
   / Where Do You Get Your Points and Condensers From? #6
An EI conversion of a 6 volt system is less than ideal. It can be difficult to maintain sufficient voltage while cranking for the EI unit to function. I used to discourage sales of 6V EI units in favor of an EI install combined with a 12V conversion. That gets spendy and if the cost isn't acceptable then I'd recommend sticking with points.
Never in my lifetime. Im not a fan of them.
   / Where Do You Get Your Points and Condensers From? #10
When I put the Hall system on the Alfa, it would idle smoothly at about 600 rpm every time. And, after a couple thousand miles, it would start missing at upper rpms.
Points and condenser are REALLY OLD technology.
Nissan Forklift (A55973)
Nissan Forklift...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
JLG 1255 Telehandler (A56438)
JLG 1255...
Quick Attach Hyd. Compact Roller (A59814)
Quick Attach Hyd...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
