Kubota B2650 PTO Selector Lever
   / Kubota B2650 PTO Selector Lever #1
clemnd86
Member
Wareham, MA
Kubota BX 2200
I cannot switch my PTO from rear PTO to mid PTO. The lever is stuck/binding. I have tried engaging the rear PTO and then trying change the selector lever and still was not able to change to the mid PTO. I applied spray grease at the lever to loosen the joints and the lever is still binding. Any thoughts what is wrong?
   / Kubota B2650 PTO Selector Lever #2
Not sue but it seams like there is a issue with the mech. Did it work before ?
   / Kubota B2650 PTO Selector Lever #3
Instead, use a penetrating spray where the shafts enter the case.
   / Kubota B2650 PTO Selector Lever #4
On my BX I had a loose bolt from one of the many brackets on the underside block the linkage.
I took it to the local dealer he was able to get it unstuck and one of the linkages was bent that he needed to straighten. Working good now.
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
