Rock Crawler
- Joined
- Aug 15, 2017
- Messages
- 2,243
- Location
- Pittsburgh, Pa.
- Tractor
- 2021 Kubota L3560 HSTC, 2011 Craftsman Excellerator GT (680hrs), 2018 Husqvarna TS354XD, 2017 Husqvarna HU800AWD, 2019 Kawasaki Mule Pro DX (Yanmar)
A body in me or trying to revive an old wiser 40 produced 11/1989.
There's a bank of 4 valves at the front that control your hydraulics using an electric motor to generate hydraulic pressure. When you rotate the lever your rotating the centre shaft on the hydraulic valve and at the same time the end of the shaft is swinging the contact to engage the electric pump. So both things must happen at the same time, otherwise it's a closed centre valve and if you turn the pump on its deadheading. So the one valve has the shaft broke where would go out to the lover, right now I have the end cap off and on reaching down with pliers and rotating the shaft and spinning the contactor at the same time There's a bank of 4 valves at the front that control your hydraulics using an electric motor to generate hydraulic pressure. When you rotate the lever your rotating the centre shaft on the hydraulic valve and at the same time the end of the shaft is swinging the contact to engage the electric pump. So both things must happen at the same time, otherwise it's a closed centre valve and if you turn the pump on its deadheading.
So the one valve has the shaft broke where would go out to the lover, right now I have the end cap off and on reaching down with pliers and rotating the shaft and spinning the contactor at the same time. This is the Valve that Clamps the log into the backstop to hold it still water cutting.
We called wood mizer and they told usThat these valves are no longer available, and that we would have to buy a $1000 complete assembly to replace this one broken valve. I am not looking for an exact replacement valve, I'm looking for any electrohydraulic valve that I could retrofit to make this work.I don't mind if I have to mount theValve outside of the valve housing because it's a different size or something.
Would any of youKnow where I could find an electromechanical valve assembly that could replace this valve?View attachment 675578View attachment 675579View attachment 675580View attachment 675581View attachment 675582
