Dirty oil, but clean dipstick.
   / Dirty oil, but clean dipstick. #11
You are looking at a thin film of oil on the dipstick. Oil in a pan is an entirely different matter.
   / Dirty oil, but clean dipstick. #12
New oil, changes to dark almost immediately. The main cause of darkened oil is not "dirt" but heat.
As oosik states, you cannot compare a thin film of oil to a panful as the density of oil particles is not only blocking light but adding to its color saturation as well..
   / Dirty oil, but clean dipstick. #13
No not always. Did you read post #2? The oil in my tractor is nearing 100 hrs and is just now starting to get noticeably darker…
   / Dirty oil, but clean dipstick. #14
It does start to change color very quickly. I changed mine out at 50 hrs and it was darker than what was first put in there for sure.
But you're right, I should have stipulated however as the word 'immediately", is relative for me in comparison to other things not so immediate such as changing oil out at 1000 miles instead of 5000 with respect to autos.
1000 miles to me would be "immediate" in the scheme of things and to think I actually did that when I was a pup.
   / Dirty oil, but clean dipstick. #15
how quickly it turns darker depends on the engine series & type of use. of course, lots of cold starts & short runs will darken oil quicker. it takes quite a while for oil to turn completely dark in my Tier II engine.
check the dipstick with engine dead cold. it should be close to oil pan color. the idea of checking dipstick with slightly drained oil is a good one to compare
Be awhile before I get back to the farm to check it
   / Dirty oil, but clean dipstick. #18
Oil does some odd things sometimes. When I check my oil cold the oil on the stick is black. When I check it hot it appears nearly clean. Yes, I check my oil before and after using the tractor. I assume then when I check it after running that the soot is evenly distributed in the oil and when it cools the soot settles out and gets deposited on the dip stick.
2020 John Deere 450M Round Baler (A53485)
2020 John Deere...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2019 WACKER NEUSON CORPORATION DBA WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
