Grillo G110D tumble but won’t start (Solved)
   / Grillo G110D tumble but won’t start (Solved) #1
shastri1986
G110D
Good day
I have a G110 day that was working fine and I switch it off and now it won’t start when I turn the key it tumble and gives out a white smoke. It’s a electric start single cylinder Diesel engine 2020 model.
I check the following battery is good , it have fuel, oil is good.
Check the last page it was a air lock in the fuel system
Please see video
Thanks for the help I’m not a mechanic but I have some sort of knowledge on small power tools.
   / Grillo G110D tumble but won’t start (Solved) #4
Check that the engine stop lever, cable, and the actual cam on the side of the engine have returned to the "run" position. Mine doesn't tend to "spring back" to "run" and I have to remember to manually return the lever to the correct position. Still fools me every now and again.
Does it tumble when it do ? Did you get a chance to play the video and where exactly is the cable located ?
Can you put out where the parts are located on the tractor
Would be greatly appreciated
I uploaded some pics can you point out where to check
   / Grillo G110D tumble but won’t start (Solved) #8
It's the lever you push on the left handlebar to stop the engine (on mine anyway). I believe the cable runs to the front-bottom corner of the engine on the air intake side (which would be the top right area in your photo, but vertically at the bottom of the side of the engine). I can take a look tomorrow. From memory there are two cables that control engine speed and the engine cutoff in that spot - the engine speed is tight and difficult to move, but the engine stop is very floppy. It could even be that the bit of cable left on the end got folded up or caught on something.
Just a update I spray starting liquid in the air in take it started but when the engine is cold it won’t start, before this engine use to start normally so I don’t know what’s causing this problem if it have a heater ?
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
UNUSED BIGFOOT AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED BIGFOOT...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2007 SHOP MADE MARATHON 20KW GENERATOR TRAILER (A58216)
2007 SHOP MADE...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
1992 Trail-Et (A57148)
