Help, replace gearbox on skid loader bushhog now it runs backwards.
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #1
Boof621
Bobcat T630
Ran a new bush hog with no oil in the gearbox and of course it locked up. Ordered a new gearbox and a couple guys in our shop swapped it out. For some reason they disassembled the motor, not sure why. Now it spins in the wrong direction at full torque and it will spin but has no power in the right direction. They have no idea what they may have changed. Can someone help me?
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #2
How many hoses 2 or 3?
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #5
Is this on a skiddy out front? Or a rear mount?
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #6
Agree with Roustabout above.....try swapping the hoses. If the connections are different, might have to swap the connections on the mower side.
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #7
Yup, that was my question about hi-flow or not. Swap the quick connects on the implement side and see what happens.
Best,
ed
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #8
My brush hog cuts rotating either direction. The the blades are sharpened on both edges. I thought all skid steer brush hogs were made this way.
   / Help, replace gearbox on skid loader bushhog now it runs backwards. #9
You hooked the hoses up backwards. No big deal, just swap them
Swapped hoses and all it does is operate the opposite direction same symptoms. This one is single direction. The blades are only sharp on one side. I think it is a check valve at the motor that was reassembled wrong. This is a standard duty front mount hydraulic bush hog. Any other suggestions?
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
