Paint quality
/ Paint quality #1
Boss 302
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
How does the paint hold up on the Massey's? I have seen a lot of fairly new red tractors (different brand) that don't do well in the sun, hoping the Massey doesn't skimp on the paint.
/ Paint quality #2
The paint on mine has held up well, but I noticed that the plastic parts (around the sides, below hood) showed a fair bit of fade after only 2 years. I don't park it in the sun any more.
The paint on my backhoe, on the relatively sharp edges of the steel parts, was not great. I made the mistake of driving it on the road -- which had been salted-- to plow/blow a friend's driveway and the edges of the steel started rusting, then began to lift the paint, working its way inward further & further. I eventually removed the "control panel" and had it sand-blasted and powder-coated. Rust also appeared on the edges of the steel rear fenders.
Moral: DON"T drive it on salted roads.
/ Paint quality #3
Mine's doing alright in most places. My boots have wore off the paint by the floor board, but I'm planning on hitting that spot with MF red spray can I got from TSC, should be fine.
/ Paint quality #4
I have decades of experience in this field, so I know what I'm talking about. It's cheap paint just like all the others.
I can live with the color fading, but I can't live with the paint not protecting the metal from corrosion. The undercoats, (the metal prep, and primers), is where they all skimp the most. Irving's photo is a classic example of this.
Manufacturers are using a lot of direct to metal paints to save money, and that isn't going to protect anything that is outdoors very well.
The competition in the subcompact market is pretty strong, more reason to keep costs down. And, reds are the most expensive to make. Quality paint in red, is shockingly expensive. In automotve paint, I've bought 1/2 pints of red that were almost $200. And, that's just the color. you still need chemicals to add to it to spray it. And clear to top it. There are aerospace level coatings that exceed that price point by a lot.
/ Paint quality
I was just under the assumption that a lot of the manufacturers didn't add the catalyst and hardener like automotive paint has.
/ Paint quality #6
I never understood people who park their tractor and implements out in the weather all year long. I see this frequently in the rural area where I live.
/ Paint quality #7
I have a 2001 MF231S that bought used in 2010. The previous owner let it sit out all the time, it was faded to almost orange color. The paint on the loader frame is still red.
/ Paint quality #8
I suspect you're right, Ray. When I started to sand mine off (prior to deciding it was worth it to have it blasted instead), there wasn't much evidence of primer. I'll put a photo below that shows how extensive the rust "creep" had become -- look at the metal discoloration; I was getting more & more large flakes peeling off as time went on, very annoying to an OCD person like me! :)
The other thing I felt was that the relatively sharp edges of the original piece of steel made it so paint on the 90 degree edges was extremely thin-- that's where the problems started. The nice thing about the media blasting was that all the edges became rounded a bit, an improvement, I think.
I thought I'd be able to re-use the old stickers, but it wasn't worth it -- for less than $30 I got a new set from AGCO. The red powder-coat paint isn't a perfect match, but it's close enough for me. Result was I'm happy, and it shouldn't have any paint peeling & rust issues again... at least that one part!
BTW -- you can see this was done in 2017; I got the tractor in Feb of 2008.
/ Paint quality #9
An activator/hardener, isn't optional in modern paint systems, it's required. The paint will never set without it.
Factories use different paint systems all together. They need to assemble stuff right after it's painted, so they use high temperature, baked on finishes. They commonly do this at temperatures as high as 450F. Which is almost three times hotter than the temperatures we force dry, in body shops. (If we tried to use the coatings the factory does, the temperatures required would melt most of the car).
Factory automotive finishes can achieve a higher level of hardness than even the high end aerospace, air dry coatings we use, can achieve.
/ Paint quality #10
View attachment 719943 View attachment 719944 View attachment 719945
The undercoats, (primer), should bond to the topcoats. So you won't commonly see primer if you scrape the paint off. If you do, they didn't bond, and that's bad.
To find evidence of any undercoat, you need to look at the back side of the paint chips that came off. If they used primer, you'll see it there. If it's the same color as the top coats, they used a "direct to metal" finish, which is fine, if your painting your metal building.
It's about more than just spraying a coat of primer on something before you paint it. It's about how you prep the steel, (cleaning and sanding), how you chemically prepare the metal, to begin with. And, what you use to create a barrier, (primers, sealers), before the paint is applied.
/ Paint quality #11
I've dealt with parts depts as well as mtx records in large regional airline and paint/corrosion prevention measures a a HUGE item.
and you can tell the quality is a lot better.
/ Paint quality #12
Aerospace coatings are better. But, not a lot better than a good quality automotive finish system. With the cost of aerospace coatings exponentially higher, they really aren't worth it, unless your painting a private jet.
I've used them over the years, and I don't find a need to go that nuts.
I have painted a lot of aircraft parts, even helicopter parts. Never had any issues getting automotive paint to hold up.
/ Paint quality #13
Mine is doing ok only because its always parked inside and i used to wax it with Mothers. But no-most tractors are not painted with good quality paint-that includes implements. My box blade which is powder coated included-however, they will still outlast me.
/ Paint quality #14
Nice job. The cover is different on yours than mine. Mine is just one big opening up there for the joysticks and stabilizer levers. I like yours better.
/ Paint quality #15
The biggest factor in keeping your tractor from corroding, is the same as with your car. Keep it dry.
Don't do things like wash it and put it in the garage, where moisture will remain in places for days.
Manufacturers don't like to spend time doing things like rounding the edges of metal after they cut it. The reason that is important is, sharp edges don't take paint. Try painting the sharp edge of an old knife, and you will see that even after 50 coats, you can still see through it, on the sharp edge. Couple that with a cheap paint, that has no undercoat system, and it's inevitable that it's going to fail like it did for Irving.
/ Paint quality #16
Ray how do you know that all the tractor manufacturers are not using quality paint and finishes as you have stated here? I'm not here to challenge you just curious.
/ Paint quality #17
It's a highly competitive market. And, paint materials are very expensive.
There is also often pressure from government agency's to comply with air quality regulations.
/ Paint quality #18
How is it that the automakers can produce products with quality paint but the tractor manufacturers can not?
/ Paint quality #19
The question should be, how is it that automakers produce products with quality paint systems, but tractor manufacturers chose not to?
The primary reason would probably be road salt forces car manufacturers to protect them better. A typical direct to metal paint system would not do well at all protecting the thin body panels on a car from corrosion.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2019 Ford F-150 Pickup Truck (A59230)
2019 Ford F-150...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
