Ford 345 D won’t move
   / Ford 345 D won’t move #1
Herbertneedshelp
Ford 345D
We bought a Ford 345d industrial tractor for our animal sanctuary mostly for around the farm and putting out round bales. Problem is I’ve been working on it a lot and I just can’t seem to get it running right, I’ve had it moving but with no power at all somehow some water had gotten into the hydraulic fluid and I’ve changed it out twice but there’s still some water in it. I’m not sure if that’s the reason it doesn’t wanna move or if it’s something else. Pulling my hair out over this thing for like nine months now or. We need this thing to be operational so badly and we really could use some expertise to get us on the right track.
   / Ford 345 D won’t move #2
Without more information it will be very difficult to diagnose over the internet. I believe this tractor is hydrostatic but not sure so water in the hydraulic fluid is never a good thing. Water might be getting in at the bottom of the shift stics. When you say it has no power does that mean the engine is bogging down or that the power is not getting to the wheels because of the transmission?
It would also help to know what you have done so far to try to remedy this problem.
Thank you so much for responding, I really appreciate it. When I got it there was a leak so I had to replace two hoses on the hydraulic cooler right behind the grill , I just changed the air filter Because the light was on and I thought it might help, I’ve tried to change the hydraulic fluid twice but there was still water in it afterwards, I also changed the one hydraulic filter but this tractor has two hydraulics, The one for the steering is hydrostatic and the main hydraulics is the Hydro-trans. Power isn’t getting to the tires to make it move, when I give it throttle it sounds pretty good, when I put it in like hi and fourth gear it will start to move and then Peter out. It would explain a lot if the water was still getting in from somewhere like the gearshift, I don’t have a place inside to store it yet But it has a ROP roof thingy. It’s hard to get all the old fluid out when I change the fluid. But there’s definitely still water in it, I would feel better knowing that’s where my loss of power is And if I can get all the water out that will be the culprit.
   / Ford 345 D won’t move #4
Not sure which light you are talking about. Does it have a light for the air filter??
Water can be difficult to remove once inside the hydraulic system. It might require a drain and fill a few times. The important thing is to find out where the water is coming from. Just because it has a roof does not mean water can't get in through the gear shifters if there is a wind blowing. Perhaps you could post some pictures of the shifter's bases. I would certainly be checking the seals and other areas where water could be getting into the transmission.
Water contaminated hydraulic fluid would also likely be in the loader cylinders and they need to be activated when doing the drain and refill.
Can you lift the tractor's front end with the loader all the way to the end of the cylinder travel?
   / Ford 345 D won’t move #5
I'm not positive on your tractor, but I do believe that all of those tractors use a torque converter drive.
Usually there is a "de clutch" switch in the system to take the torque converter power away when lifting
a load in the loader and wanting rpms without the tractor moving. It could be a bad torque converter, a wiring issue
or contaminated fluid. You need a serice manual for that tractor.
I think you just hit on my problem. I knew there had to be more fluid in the system I wasn’t getting out but couldn’t figure out how to go about getting the rest out. I’m really looking forward to my next drain and refill cycle now!!
I will take pictures of the shifter base and put them on here. That’s the other part of this.. how is it getting there in the first place. The radiator fluid has stayed full and when I run it the fluid level doesn’t raise, so I assumed at first previous owner somehow got it in there by human error. Now I’m thinking it’s getting in there somehow when it rains. So I’ll post shiftbase and maybe we can figure this out. Really appreciate your knowledge and insight. And the light was on the dash when I accelerated it would come on, but light is now a aging off after change of air filter. So it was a needed change but not the culprit of why it wasn’t moving..
Thanks for your reply @LouNY , it’s does have a torque converter and the “de clutch” I was worried that it might possibly be stuck on “de clutch” but I think that is working ok. After my last drain/refill It would move but wouldn’t engage all gears, mostly only 4 hi. I’m hoping it’s only the water in the fluid and I just have to get it all out to have a working tractor. I still worry there could be a problem with torque converter.. I really hope it’s the fluid. You also got me thinking about the wiring, because Working on a used tractor I’m always worried about who worked on this machine before.
   / Ford 345 D won’t move #8
If you suspect water contamination you really need to change filters with the oil change. There are probably multiple drain plugs and maybe even a low pressure hose to undo to drain the hydraulic system. The 4500 ford I had used part of the lower loader frame for oil reserve. Really need owners or shop manual to know the proper procedure for maintenance. Some have a suction screen that needs cleaned when oil is drained. Worth their weight in gold for any DIY maintenance.
4 high is a highway gear at best. Try lower gear.
Old suction hoses can crack and allow air into hydraulic system and aerate the oil often with little oil external leakage. Check them and replace when oil is drained.
Good you replaced leaky hoses. Any external leaks are possible entry points for water.
Almost too clean. Be very careful pressure washing a tractor or from a previous owner.
   / Ford 345 D won’t move #9
Seems like a nice tractor. We need to back up here a bit.
Lets back up a bit here. How do you know that you have water in the oil? What do you mean when you say "Peters Out?". Water in the oil is not good, but it won't keep it from moving. Or does it move? Does the loader work? Does it start up OK?
Is the hydraulic cooler an air flow type or does it have a water jacket?
When I get an old machine the first thing I do is get an owner's manual, parts book, and service manual. Ebay has them. The original manuals are always the best. typical prices range from $50 for owner's manuals to $150 for an original service manual in a 3 ring binder.
I think there is a
I changed the two hydraulic filters but one of them was for the hydrostatic hydraulic steering. There’s a little screen like a bucket with a handle inside the hydraulic reservoir. That was hard to get out so I didn’t mess with it last time any further. I’m getting ready to do a new fluid change on the hydraulics tomorrow hopefully with the loader bucket up all the way I’ll get all the water out. I’m worried that it’s not gonna fix the problem as to why the tractor barely moves
2025 14ft Bi-Parting Gate (A56859)
2025 14ft...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
2004 Freightliner FLD120SD Day Cab Truck, VIN # 1FUJALCK54DM74906 (A57453)
2004 Freightliner...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
