BackRoad
Only Titan product is my forks...no County Line or King Cutter equipment. Everything else is Woods, Rhino, Land Pride (pre Kubota ownership) or EA.
Go for the Woods...you'll cry once when you buy it - but it should hold its value.
Assume you are planning for 10 years use, not 1 year. Figure out the difference in cost divided over 10 years. It will be very, very small...
Tractor implement are long-term investments...invest in the best you can find. In the long run, it pays off in reduced maintenance, faster job completion, extended durability and pure satisfaction from using a quality tool.
Life is too short to use junk....(not saying Titan is junk) but it's not on the same level as the Woods...or Rhino...or higher-end LandPride...or Brown...or...
(in my opinion of course, with deference to any Titan owner!)
