/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 15,763
Just built a hydraulic chainsaw for the tractor. All taper to taper NPT threads used Loctite 545. All swivel NPT to taper NPT used no sealant. These allow easy assembly and service of component parts. No leaks.
The NPSM fittings used on valves, cylinders etc. also make it simple to order hoses...with the NPSM the end(s) of the hose can be straight male pipe thread (NPT)...the mechanical joint eliminates the need for sealant and re-using the fittings (NPSM) is not a problem....
Female Pipe Swivels (NPSM)
The National Pipe Straight Mechnical (NPSM) female fitting has a straight thread and an inverted 30? seat. The male fitting has a straight thread and a 30? internal chamfer. A properly chamfered NPTF male will also seal with the NPSM female.
www.discounthydraulichose.com
