tc55da fuel knock
   / tc55da fuel knock #11
You sent the head in and it checked out fine. How did they check the flatness? Did they use a straight end or did they run it across a planer or flat grinder to check?
   / tc55da fuel knock #12
I would surmise with a straight edge, hopefully. Something you can to at home with a length of ground flat stock and a feeler gage.
   / tc55da fuel knock #13
If your leaning towards the head gasket, u can try loosening the injector line 1@a time & retighten and listening for the knock to go away..
At least u might narrow it down to a specific cylinder..
Good luck with it..
   / tc55da fuel knock #14
What the heck is a 'flat grinder' ? You mean a surface grinder maybe? You don't use a planer to deck a head anyway and you'd never use any machine tool for checking flatness. Always done on the bench with measuring tools.
   / tc55da fuel knock
finally had a chance to check it out, reset valves, had one off, i remember getting a call when i was setting them, so i must have missed 1. no more multitasking! runs like a champ again. Thanks for all the replies.
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
New Idea Tandem Manure Spreader (A50774)
New Idea Tandem...
2023 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2023 Isuzu NPR-HD...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
Edco Hand 12" Post Hole Digger (A50774)
Edco Hand 12" Post...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
