tc55da fuel knock
   / tc55da fuel knock #11
You sent the head in and it checked out fine. How did they check the flatness? Did they use a straight end or did they run it across a planer or flat grinder to check?
   / tc55da fuel knock #12
I would surmise with a straight edge, hopefully. Something you can to at home with a length of ground flat stock and a feeler gage.
   / tc55da fuel knock #13
If your leaning towards the head gasket, u can try loosening the injector line 1@a time & retighten and listening for the knock to go away..
At least u might narrow it down to a specific cylinder..
Good luck with it..
   / tc55da fuel knock #14
What the heck is a 'flat grinder' ? You mean a surface grinder maybe? You don't use a planer to deck a head anyway and you'd never use any machine tool for checking flatness. Always done on the bench with measuring tools.
   / tc55da fuel knock
finally had a chance to check it out, reset valves, had one off, i remember getting a call when i was setting them, so i must have missed 1. no more multitasking! runs like a champ again. Thanks for all the replies.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2020 Freightliner M2 106 Dump Truck (A50323)
2020 Freightliner...
(250) Safety Traffic Cones (A50121)
(250) Safety...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
