1996 JD 6200 Fuel Pump/Tank Filter
   / 1996 JD 6200 Fuel Pump/Tank Filter #1
powerplusdude
Vidalia, GA
2014 JD 5075E
1996 JD 6200 Open Cab: I refuse to believe that I have to buy a whole new fuel pump to get a new filter/strainer that is installed on the end of it. Dealer wants over $100 for a new fuel pump. I would think the filter on the end would only be a few dollars and should be a separate part. Does anyone know how I can get a filter without buying the whole fuel pump assembly? Part numbers would be a plus as the two different dealers I deal with can't figure out nothing unless I give them a part number. I am even open to an aftermarket filter. Pics for reference:
Thanks for the help!!
Mike
   / 1996 JD 6200 Fuel Pump/Tank Filter #2
Mike
Gosh only $100 for a JD part! Sounds cheap.
You might try looking for a JD on-line parts catalog and see if you can get a part number there. Can you clean the existing strainer out and re-use it?
That’s what I did. Cleaned it best I could and stuck it back on there. That’s where I got the diagram picture at. No part number that I could find.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
UNUSED INDUSTRIAS AMERICA HI100T HYD TILT LAND LEV (A51247)
UNUSED INDUSTRIAS...
1997 HONDA FOREMAN 400 ATV (A51247)
1997 HONDA FOREMAN...
(APPROX 250) UNUSED TRAFFIC CONES (A51248)
(APPROX 250)...
