Shibaura 1540b 3 point won’t lift
   / Shibaura 1540b 3 point won’t lift #1
Neil1982
2008 Massey Ferguson GC2310
I just purchased a Shibaura 1540b and it was having hydraulic issues caused be a clogged screen. After draining the oil and cleaning the screen the loader works perfectly but the 3 point doesn’t want to lift. It will only lift while cold or if I shut down the tractor for a few min but sometime that doesn’t even work.
Any suggestions on what it could be?
I’m thinking piston seals….
   / Shibaura 1540b 3 point won’t lift #2
You may get answers if posted in the Ford compact section or the Shibaura section. This section is for easy hydraulic questions. Not a hard one like this since it's a Gray Market imported machine from Japan built to JIS standards and not SAE.
   / Shibaura 1540b 3 point won’t lift #3
Knob under in front of seat. Take out and check o ring.
   / Shibaura 1540b 3 point won’t lift #4
IS this a D1540 or a SD1540 or a SP1540 ? You are missing the first 2 letters for the series.
Sd1540b
   / Shibaura 1540b 3 point won’t lift #6
Nice. :)
That is one manual I do have and can share here. :)
You can look at the parts diagram of the hydraulics and see if something isn't right.
  • SHIBAURA SD1500 SD1540B.pdf
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2015 Freightliner Cascadia 125 Day Cab Truck, VIN # 3AKJGEBG5FSGD4138 (A54865)
2015 Freightliner...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
