how do you get to the ignition switch on a 3020 John Deere to replace it
   / how do you get to the ignition switch on a 3020 John Deere to replace it #1
dvaidm77
John Deere 3020
what do you have to remove to get to the ignition switch on a 3020 John Deere gas model
   / how do you get to the ignition switch on a 3020 John Deere to replace it #2
Welcome to TBN
Is your 3020's serial # below or above 123,000? Below 123,000 one removes one bolt(item 46) that allows cowling to be removed that ign switch is attached to with a large nut. On later model side panel removal requires removing a nut(item 16) then slide side panel(item 1 &/or 17) rearward. To access nut one needs to remove side shield that has 3020 decal attached.
Welcome to TBN
our 3020 serial number is 134511r
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
ITEM LOCATION (A53084)
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
