how do you get to the ignition switch on a 3020 John Deere to replace it
   / how do you get to the ignition switch on a 3020 John Deere to replace it #1
dvaidm77
John Deere 3020
what do you have to remove to get to the ignition switch on a 3020 John Deere gas model
   / how do you get to the ignition switch on a 3020 John Deere to replace it #2
Welcome to TBN
Is your 3020's serial # below or above 123,000? Below 123,000 one removes one bolt(item 46) that allows cowling to be removed that ign switch is attached to with a large nut. On later model side panel removal requires removing a nut(item 16) then slide side panel(item 1 &/or 17) rearward. To access nut one needs to remove side shield that has 3020 decal attached.
Welcome to TBN
our 3020 serial number is 134511r
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A55788)
2011 FORD F-250...
2014 Ford Escape (A50324)
2014 Ford Escape...
