Replacing regular with GFCI. - Solved Thanks All
   / Replacing regular with GFCI. - Solved Thanks All #11
Yes you "should" replace with gfci to be up to code but only 1 on the circuit is required. If you have 2 on same circuit can lead to constant tripping. BTW don't expect the new gfci outlets to last 25 years, lucky to get more than 5
   / Replacing regular with GFCI. - Solved Thanks All #12
Consider a whole house surge protector at the meter (installed by utility company) to project your internal outlets, and appliances from power surges.
   / Replacing regular with GFCI. - Solved Thanks All #13
My mother in-law has this happen in her garage quite often. All of the garage outlets go dead and they can't figure out why. I show them the GFCI outlet that they stack firewood against and trip the test button, suggest they not to pile stuff in front of that outlet, show them how to reset it, they nod and say thanks and it happens again next year. ;)
Maybe it is time for a nice mother-in-law gift of a robust outdoor outlet cover for the firewood outlet?
Thanks guys. I did think it odd that they both went out. Those house is about 25, so not brand new, but not 'old' either. During day light, I will check...it may be the exterior plug...I hope it is not the garage, because the freezer is on that circuit.
Gosh, me, too. Freezers and refrigerators ought to be on a dedicated circuit for these sorts of issues.
From your description, I would be strongly suspecting that there is another GFCI somewhere that is tripped. One outlet might, might, be bad but two outlets being bad at the same time is so improbable that I would be looking for other causes, like an unknown GFCI outlet, or rodent damage, or that the breaker is bad.
All the best,
Peter
   / Replacing regular with GFCI. - Solved Thanks All #14
You said you had "no power" at the outlets.... have you checked to see if another GFCI somewhere else is tripped? Might be a simple fix!
That's a good point. In our house, the upstairs bathroom outlets are on the same circuit as the downstairs half bathroom. If the upstairs outlets lose power, I've learned to check the GFCI in the downstairs bathroom.
   / Replacing regular with GFCI. - Solved Thanks All #15
The only problem I’ve had is there is a little less room in the box for a GFI. I’m scared to death of wiring and electricity but I will wire things like a GFI.
   / Replacing regular with GFCI. - Solved Thanks All #16
If you are scared to death of wiring, please hire this out. Electricity should be/must be respected.
   / Replacing regular with GFCI. - Solved Thanks All #17
At the hospital all medical GFCI with no downstream use.
I follow the no downstream at the rentals I manage because it simplifies things.
Having an upstairs bathroom control a garage or outdoor is pennywise and pound foolish in my opinion as one who tracks down problems.
The green indicator lamp built into many GFCI is a bonus.
GFCI don't last forever especially exposed to elements... found many that will not trip when tested.
My current home has them but prior never lived in a home with them and way back no grounds either.
   / Replacing regular with GFCI. - Solved Thanks All #18
All the best,
Peter
Local electric code requires the refrigerator to be on a dedicated circuit but when people add a second or 3rd refrigerator or freezer there’s really no enforcement on that. The freezer in my garage isn’t on a dedicated circuit but I did move the GF to the second outlet so it doesn’t protect the one the refrigerator is plugged it to.
   / Replacing regular with GFCI. - Solved Thanks All #19
They make ground fault breakers. They cost 2.5 times more than the GF outlet but if the outlet keeps getting ruined it might be worth it.
We have a winner! This is exactly what it was. The upstairs 1/2 bath that is rarely used is the one where they put the GFCI on the circuit. All fixed. My wife thanks you.
+1 on @jyoutz whole house surge protector is relatively cheap and effective.
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
Carnival Ticket Booth (A51691)
Carnival Ticket...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
