Lucas X-tra heavy duty grease sold out?
   / Lucas X-tra heavy duty grease sold out? #21
Can’t get my Lucas green grease anywhere.
Anyone else seeing this where you live?
I need for my square baler and I don’t like mixing greases.
Same here. In my area in 2020 WM had Lucas green for less than $5 a tube and had a case in stock all the time. That ended last year, so I got a case off Amazon for $6 a tube. Now all the Amazon vendors are scalping Lucas for $13+ a tube. No thanks. I found a case of JD SD polyurea for a little over $7 a tube (with tax) and ordered that. Think it’s gonna be a challenge next year when reorder time rolls around…
   / Lucas X-tra heavy duty grease sold out? #22
It appears that a major contributor to the grease shortage is the fire and explosion at the Rocktonm, Il. Chemtool plant.
This, combined with a sharp increase in demand as the economy started again, has led to supply shortages.
   / Lucas X-tra heavy duty grease sold out? #23
I remember when that happened, didn't connect what kind of facility it was at the time. I'm pretty sure that's the fire we could smell even though it's a good hour's drive from us.
Around here the grease shelves cycle between full and empty, when I see some on the shelf I buy 6 tubes instead of 2 because I know there probably won't be any next time. Everyone's probably doing the same thing so they run out right away when they get a shipment.
   / Lucas X-tra heavy duty grease sold out? #24
This is an example of the Bullwhip effect in action.
The bullwhip effect is a distribution channel phenomenon in which demand forecasts yield supply chain inefficiencies. It refers to increasing swings in inventory in response to shifts in consumer demand as one moves further up the supply chain. The concept first appeared in Jay Forrester's Industrial Dynamics (1961)[1] and thus it is also known as the Forrester effect. It has been described as “the observed propensity for material orders to be more variable than demand signals and for this variability to increase the further upstream a company is in a supply chain”.[2]
Cory Doctorow talks about this in a recent piece: After inflation, the whip-crack.
His viewpoint will seem a bit radical to some here, but he makes some telling points:
The less a country can make on its own, the more vulnerable it is to shocks on the other side of the planet. The more the markets reward emptying out buffer stocks, casualizing workers, and selling off your physical plant, the more your company is at risk of failing if anything goes wrong, anywhere.
The more manufacturers and more competition we have, the better off we are... and when one accident with a High-Lift installing insulation causes years worth of grease shortages, its a clear indication that too much concentration has occurred.
   / Lucas X-tra heavy duty grease sold out? #25
Amazon might be one place..
Jeffy’s price gouging.
I finally have found some locally for $6.99/tube.
Ordered a 30 pack from Summitt Racing for $150.
   / Lucas X-tra heavy duty grease sold out? #28
I have had a case of red and tacky on backorder through one of my mower parts distributors since the first part of May.
Why? Its available on ebay right now for $75 a case. Within $10 of when I ordered it a year ago.
They said grease and oil shortages where coming.
   / Lucas X-tra heavy duty grease sold out? #30
Looks like my local Menards now has it for $6.99-11% Right now. 27 tubes in stock. I an not hurting for grease right now so I will wait on my normal backorder shipment because I pay less than that for a case.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
