Great lake boats, a good video
   / Great lake boats, a good video #951
Been to Whitefish point and Beaver island, there museums have interesting info and exhibits about the wreck.
   / Great lake boats, a good video #953
Looks like the Chief engine room operator gave it a tad too much fuel, hence the back smoke...
   / Great lake boats, a good video #955
Not supposed to occur. Fueling ratios are an important aspect of operation. Besides, it looks bad.
   / Great lake boats, a good video #956
What is blast furnace trim?
Can't seem to find it online.
   / Great lake boats, a good video #958
Raw crushed taconite used to adjust silica content in steel making process?
   / Great lake boats, a good video #959
Watching the video's of the 'Big Boy' Love that steam engine... and how the fireman controls the flow of oil and the resultant smoke, you can quickly see that too much fuel oil at once causes the black smoke because it don't all combust. You notice that there is a large black cloud, then it dissipates and in the last of the video, the stack is emitting mostly heat and very little smoke as the fueling ratio is under control again.
I imagine, unlike the Big Boy, the fireman on the boat cannot just look at the stack and observe the amount of smoke being emitted.
I believe the more modern Lakers use piston engines instead of boilers and they post treat the exhaust with I presume either some type of electrostatic precipitator or inject DEF. Don't know for sure but they do emit little to no visible smoke, mostly hot moisture laden exhaust which tells me some sort of pollution abatement is ocurring.
-----------------------Just some lake news---------------------------------
MARQUETTE, Mich. (WLUC) - Lake Superior is experiencing its coldest season in over 25 years due to cool winter and spring temperatures.
Lake surface temperatures are about 10 degrees lower than this time last year, according to National Weather Service data.
“Right now, if you average all of the surface temperatures on Lake Superior it’s right in the middle the lower to middle 40s, typically would we see the temperatures to be in the lower to mid-50s at this point in the summer season,” National Weather Service Meteorologist Matt Zika said.
Lake Superior Watershed Partnership Project Manager Solomon Kronberg says due to the fluctuation in water temperature, the lake will experience more algae blooms.
“We’ve had algae blooms recently, but none of them have caused even close to the number of issues that algae blooms in the southern lakes have caused,” Kronberg said. “Along this general warming trend that will be more common.”
Plants are not the only part of the ecosystem experiencing trouble because of inconsistent year-to-year summer temperatures.
“Whitefish, in particular, are really suffering because they are dealing with loss in spawning ground. This temperature issue really relates to all aspects of what it means to live on the lake or in the lake,” Kronberg said.
Zika says while the water temperature is cool this season, it’s still running above the long-term average.
“If we look historically for the last 30 years or so we have gone through more above normal temperature years than below normal temperature years,” Zika said. “Because of that, the lakes are warmer in the grand scheme of things than they were probably 40 to 50 years ago.”
Kronberg says Lake Superior is the second fastest warming lake in the world.
While experts are unsure whether low lake temperatures will follow later into the season, they remind everyone to be aware of an increased hypothermia risk as temperatures are still sitting in the 40 degrees.
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2017 Vicon 764 (A50123)
2017 Vicon 764...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
378811 (A51573)
378811 (A51573)
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
