Kubota cab phone charger
   / Kubota cab phone charger #11
With nothing plugged into the outlet it still drained the battery by virtue of it's existence? Is that right?
I ask because I'm looking to eventually install a 12 volt outlet on my Kioti, but I've never done it before.
The usb outlets will typically have a small transformer built into the plug to drop the voltage down to the usual 5v. This transformer can have a slight parasitic drain even if nothing is plugged in. On the other hand a cigarette lighter plug has no transformer and therefore no parasitic drain unless something is plugged into it.
I hope this helps!!
   / Kubota cab phone charger #12
I hope this helps!!
I appreciate you chiming it!
   / Kubota cab phone charger #13
I hope this helps!!
Very correct. Some cigarette ports are ignition switched, some aren't. No risk of a USB adapter in the outlet draining your battery if that port turns off with the key.
I put in an ignition switched auxiliary fuse box on my machine. Mostly for an overkill light setup. But I also hard wired in some USB ports.
The factory wiring harness for the cab lights is behind the right hand pillar. Those will be ignition switched plugs. Right behind a couple of knockouts for the switches. 99% sure even the stripped LE machines use the standard wiring harness.
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
