Kubota cab phone charger
   / Kubota cab phone charger #11
With nothing plugged into the outlet it still drained the battery by virtue of it's existence? Is that right?
I ask because I'm looking to eventually install a 12 volt outlet on my Kioti, but I've never done it before.
The usb outlets will typically have a small transformer built into the plug to drop the voltage down to the usual 5v. This transformer can have a slight parasitic drain even if nothing is plugged in. On the other hand a cigarette lighter plug has no transformer and therefore no parasitic drain unless something is plugged into it.
I hope this helps!!
   / Kubota cab phone charger #12
I hope this helps!!
I appreciate you chiming it!
   / Kubota cab phone charger #13
I hope this helps!!
Very correct. Some cigarette ports are ignition switched, some aren't. No risk of a USB adapter in the outlet draining your battery if that port turns off with the key.
I put in an ignition switched auxiliary fuse box on my machine. Mostly for an overkill light setup. But I also hard wired in some USB ports.
The factory wiring harness for the cab lights is behind the right hand pillar. Those will be ignition switched plugs. Right behind a couple of knockouts for the switches. 99% sure even the stripped LE machines use the standard wiring harness.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
Severe Duty Pallet Forks (A47477)
Severe Duty Pallet...
2016 JEEP Cherokee SUV (A55758)
2016 JEEP Cherokee...
2011 MERCEDES-BENZ S-Class Sedan (A53424)
2011 MERCEDES-BENZ...
Magnetek RLS500 (A47477)
Magnetek RLS500...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
