Sawyer Rob
Super Member
Did you ever find water in it??I added a Racor to my Kubota BX when I owned it. A big improvement since it came with two of those tiny ones. It didn’t have any kind of sensor though.
SR
Look to install a water separator on your 100 gallon nurse tank. I suggest something like a Parker/Racor HF900 (that is totally on sale right now) https://www.amazon.com/dp/B07QXVPN1...olid=1TQYWLHM5ELRM&psc=1&ref_=lv_ov_lig_dp_it
I’ve been looking at the Racor water separators. The one you reference here shows a flow rate of 90 gallons per hour which would be about 1.5 gallons per minute which is really slow for fueling tractors.Look to install a water separator on your 100 gallon nurse tank. I suggest something like a Parker/Racor HF900 (that is totally on sale right now) https://www.amazon.com/dp/B07QXVPN1...olid=1TQYWLHM5ELRM&psc=1&ref_=lv_ov_lig_dp_it
I think that's offshore copy of Racor since nowhere does it say it is a Racor unit?
Pretty cheap thought.
Buyer be aware - it may or may not be OK, only time will tell.
Do you have a water filter on the nurse tank pump?Like the title says, water in fuel caused me a $10,000 repair bill to my 2017 Grand L6060 with about 1200 hours on it. The water caused rust in the fuel rail which caused damage to the injectors. I have had fuel problems with this tractor since its new.
I have a 100 gal. nurse tank that I use to fuel my tractors. I assume that condensation is happening in this tank. I do add a fuel 'cleaner' to each 100 gallons I put in the nurse tank. I guess this is mostly my fault, because I don't monitor the water separator on the tractor closely enough. I will check it more often now after this.
I have a Goldenrod filter but it was not a “water block” filter. It is now.Do you have a water filter on the nurse tank pump?
I need to double check mine, didnt know there was a block version. Just getting ready to fill it.I have a Goldenrod filter but it was not a “water block” filter. It is now.
