Change shifter boots on 1970 820 3 cyl
   / Change shifter boots on 1970 820 3 cyl #1
jww1960
john deere 820
Trying to change the shifter boots, I am holding the shifter shaft with a wrench so the knobs on both just spin and spin but not coming off..what's the remedy? This is the german made 1970 3 cyl tractor. Thx
   / Change shifter boots on 1970 820 3 cyl #2
If gearshift lever knobs won't come off of lever your next option is remove retaining ring(item 7) & pull lever out of shift cover then install boot.
   / Change shifter boots on 1970 820 3 cyl #3
Try warming the knobs up with a heat gun.
   / Change shifter boots on 1970 820 3 cyl #4
Been my experience that most are a push on, friction fit. Try pulling harder and twisting at the same time.
   / Change shifter boots on 1970 820 3 cyl #5
IIRC the JD ones are screwed on. Check if new ones are available
   / Change shifter boots on 1970 820 3 cyl #7
If they are, most likely there will be a jam nut under it.
No jam nut listed for shifter in JD 820 utility tractor parts catalog.
   / Change shifter boots on 1970 820 3 cyl #8
So, there is no depiction of the shift pattern like my Kubota's have on them then? Mine screw on and a thin jam nut secures them in the correct orientation.
   / Change shifter boots on 1970 820 3 cyl #9
That's odd your M9000 gearshift knob has a thin locknut under the knob as no locknut is listed in M9000 parts catalog under either gearshift knob.
   / Change shifter boots on 1970 820 3 cyl #10
Both of them came that way, if in the parts breakdown or not is irrevelant.
KUBOTA M7-132 (A53084)
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
