harbor freight weed burner
   / harbor freight weed burner #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Got it hooked up & got propane in the tank, but when I pull the trigger it gives me a short instant of higher flow and then dies immediately
   / harbor freight weed burner #2
Many of the new valves still have the LH thread on the inside. At least on RV tanks.
   / harbor freight weed burner #3
sounds like wrong tank for the fitting. or wrong fitting for the tank.
Maybe a adapter is available
   / harbor freight weed burner #4
Weird, I use that fitting with propane bottles on my cutting torch.
   / harbor freight weed burner #6
Is this a brand New torch or an older one, Harbor Freight had a recall on those a while back
   / harbor freight weed burner #7
"All propane tanks built in the last years have an excessive flow regulator. If it senses a leak in your system it dramatically reduces the flow out of the tank. This often happens if you have a burner in the on position when you open the propane tank.
Maybe try going slow to full burn? Just a thought
   / harbor freight weed burner #8
What size tank are you putting it on?
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
John Deere 60 (A53317)
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A57024)
2022 Brush Wolf...
