Bush Hog blades not swinging freely
/ Bush Hog blades not swinging freely #22
Do your blades look anything like my old ones? They weren't cutting grass anymore, just ripping it. Quite a difference from the new blades!
Heck they may not even look that good anymore.
I recall they were definitely showing some wear the last time I was under the cutter (digging out a piece of cable that I "found" in the grass). But I wasn't really focused on the blades at the time.
Actually I think they just have a bit of wear at the tips. This is a pic from the cable wrap incident. Not a great angle to see the blades with (sorry), but I don't have any other recent ones showing the underside.
/ Bush Hog blades not swinging freely #24
correct blades and bolts. grass cutting mostly, occasional 1" sapling. part of the property is bordered by woods so some deadfall limbs maybe 2 inches. any bigger and I move limb before running over it. After sharpening I flatten cutting edge to a 1/16 or thicker. Same as I have done for years
Looks like we have a similar routine, swap out and sharpen as spares, lighter duty use, blunting the edge after "sharpening" (shaping out the nicks). I use Neverseize on the shoulders and threads of the bolts. Less likely to attract debris than grease but assures free movement. Also allows you to spin the nuts off by hand after breaking them loose.
/ Bush Hog blades not swinging freely #25
You don't need a bush hog, you need a herd of goats.
My nearest neighbors have kept a herd of goats on their property for many years. Unfortunately, there's a lot of this desert vegetation that even goats refuse to eat so each year I mow about 8 acres of their property in addition to mine, just to mitigate the fire danger around their buildings. (Fire danger is the only reason I mow my place.)
Everything mowed to 3" or less, and a wide firebreak is how I try to keep my place safe.
When I replaced the blades on my Rino 72, one of the blades was binding. Seems like the area on the stump jumper under the blade was worn. It was like a slight depression, that when I tightened the blade bolt, it forced the blade against the holder. I fixed it by putting a spacer between the blade bolt shoulder and the stump jumper. The clearance was restored, and the blade was free swinging again.
Read you post with interest. Found some flat washer spacers at TSC that are 14 ga. 1 1/2 I.D. like the shoulder on the bush hog bolts to put between the blades and stump jumper. Hopefully the extra clearance take care of this issue.
/ Bush Hog blades not swinging freely #27
The photo of used blades by DesertEagle71 show the origin of problem I had. The clean spot on the blade around the bolt means it was rubbing the blade holder.
I seem to remember TSC is where I got the spacer I used. Please post back if that fixes your problem. It'll pay it forward by helping someone in the future.
Will post after I try with the spacers. One more mowing this year, probably late Sept. Will change out blades with some newly sharpened and add spacers. Will spend the winter in a barn shed and bring it out maybe late april. Will update after first use and see if I can still swing them freely by hand.
/ Bush Hog blades not swinging freely #29
Very intriguing landscape. I think that's how Vegas looked at first.
/ Bush Hog blades not swinging freely #30
The blade hole is 1 1/2"? If so, your washers will go over the 1 1/2" shoulder that the blade swing on and compress your blades even more. I think you need a spacer that is 1 1/2" OD and an ID to fit the shank of the bolt.
/ Bush Hog blades not swinging freely #31
The blades have a drop built into them. As the blades are rotated at a fast speed centrifugal force tries to lift the outer ends to be in line with the mounting point. That is the reason you see the bright spot on the outside of the blade bolt.
od of shoulder of bolt is 1 1/2. same as id of washer. washer just extends the 1 1/2 dim. past the top of the blade more. od of washer is 2 1/2. washer will give me about another .050 clearance between blade and stump jumper. washer .075 thick but shoulder on bolt already extends .025 past top of blade So. blade mount bolt passes through hole in blade ,washer put on top of blade then mounted to stup jumper
washer sitting on top of shoulder protruding through blade.
/ Bush Hog blades not swinging freely #34
Thanks, Let us know how it works out.
/ Bush Hog blades not swinging freely #35
By your description, I don't think this will work. My washer's ID was enough to clear the threaded portion of the blade bolt but not the shoulder. The shoulder of the bolt is in contact with the washer, not the stump jumper / blade holder.
In your photo, it looks like the shoulder is through the ID of the washer.
You are correct . purchased 1-1/8 machine bushings that is bolt shank size and used 7/32 chainsaw file to clear crimped keyway on bolt . Now bushing sets on top of the shoulder with id clearing bolt shank. Post from Gene P got me thinking. Thanks Gene P. Temporarily had head up buttt. Back on right track now I think
/ Bush Hog blades not swinging freely #37
If the Stumpjumper is bent it will keep the blades from moving freely mine got bent using a forklift on it one time
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
case 370 glass door never installed (A61306)
case 370 glass...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
