amarsh64
- Joined
- Sep 9, 2014
- Messages
- 224
- Location
- Norton New Brunswick
- Tractor
- LS G3033H TLB Husqvarna YTH1942
here we go
Yeah. I was thinking that after seeing image after image with folks having their mills set up that way. I'll need some more cinder blocks and potentially more lumber. 4x4 are still a bit narrow I think. This is a temp setup which is fairly central to the property. I'm hoping to get it up on a platform and under some cover in the not too distant future. Definitely before the snow comes.Personally, I'd turn the blocks the other way, crossway to the mill deck and run the 4x4's that way too.
That's the way mines been set up for more than 20 years without problems...
SR
I need to change this up I am sure.Yeah. I was thinking that after seeing image after image with folks having their mills set up that way. I'll need some more cinder blocks and potentially more lumber. 4x4 are still a bit narrow I think. This is a temp setup which is fairly central to the property. I'm hoping to get it up on a platform and under some cover in the not too distant future. Definitely before the snow comes.
Are you using the feet? Wouldn't the cross 4x4's need to be where the feet are?One block high with a cross 4x4 works for me, I see more lumber than you need there now.
The blocks don't need to be less than 5 or 6' apart either, at least mine aren't.
Don't over think it, get milling!
SR
What size is your track?Almost there .
NO feet and no problems, you can use cross 4x4's or not. Here's mine,Are you using the feet? Wouldn't the cross 4x4's need to be where the feet are?
