Kubota L3400 3 point hitch
   / Kubota L3400 3 point hitch
So when the loader is being used, hydraulic fluid is usually returned to the tank via the low pressure return hose. High pressure goes out the pressure beyond. That's why I asked about the hydraulic lines. The power beyond hose and the return to tank might be crossed up. So, the power to the 3ph is coming from the FEL "return" hose, when you operate the FEL.
Does the hydraulic system seem to be straining? or normal sounding?
Only the 3pt sounds like it is straining until I raise the loader
   / Kubota L3400 3 point hitch #12
Your tractor has a relief valve. I also am wondering if there is some debris that got caught in there.
This may be a stupid guess but any possibility that there is air trapped in the 3 point circuit that gets alleviated when using the fel circuit acting like a pressure change relief?
Your tractor has a relief valve. I am wondering if there is some debris in there.
Any possibility that there is air trapped in the 3 point circuit that gets alleviated when using the fel circuit because of a pressure change?
i've already tried working the hydraulics to bleed air out. The filter was changed not long ago so that leads me to believe that some trash got in there and stuck at the relief valve.
   / Kubota L3400 3 point hitch #14
But wouldn't that also cause a weak loader?
1995 Cat 963B Track Loader (RIDE AND DRIVE) (NICE) (A50775)
1995 Cat 963B...
2017 Kenworth T370 Service Truck with Crane, VIN # 2NKHHJ7XXHM175924 (A54865)
2017 Kenworth T370...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
New 52" Skidloader 4in1 Bucket (A50775)
New 52" Skidloader...
2022 Bobcat T66 (A53314)
2022 Bobcat T66...
AIR LIFT 10 TON JACK (A55745)
AIR LIFT 10 TON...
