Kubota L3400 3 point hitch
   / Kubota L3400 3 point hitch
So when the loader is being used, hydraulic fluid is usually returned to the tank via the low pressure return hose. High pressure goes out the pressure beyond. That's why I asked about the hydraulic lines. The power beyond hose and the return to tank might be crossed up. So, the power to the 3ph is coming from the FEL "return" hose, when you operate the FEL.
Does the hydraulic system seem to be straining? or normal sounding?
Only the 3pt sounds like it is straining until I raise the loader
   / Kubota L3400 3 point hitch #12
Your tractor has a relief valve. I also am wondering if there is some debris that got caught in there.
This may be a stupid guess but any possibility that there is air trapped in the 3 point circuit that gets alleviated when using the fel circuit acting like a pressure change relief?
Your tractor has a relief valve. I am wondering if there is some debris in there.
Any possibility that there is air trapped in the 3 point circuit that gets alleviated when using the fel circuit because of a pressure change?
i've already tried working the hydraulics to bleed air out. The filter was changed not long ago so that leads me to believe that some trash got in there and stuck at the relief valve.
   / Kubota L3400 3 point hitch #14
But wouldn't that also cause a weak loader?
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
Unverferth Gravity Wagon (A50775)
Unverferth Gravity...
2016 Nissan Pathfinder SUV (A55758)
2016 Nissan...
2008 Ford F-450 (A53314)
2008 Ford F-450...
