Rustyiron
Super Member
I'll do either. If I need to hit a certain dimension with the cant, and the small end is just big enough I'll purposely start there. This is probably due to my lack of experience.
Lol, yeah that pretty little diagram that we've all seen years of how you get everything little inch of Lumber out of a log went "out the window" real fast for me too.I'm beginning to realize I'm losing lumber to slabs by taking too much off in my first and second cuts.
Sawing from the "top" end is the "right" way, many logs mill easier from that end.Thanks for the replies to my question. I've always seen them sawn from the small end so started out doing it that way. I'm beginning to realize I'm losing lumber to slabs by taking too much off in my first and second cuts. I also quickly discovered that you can't make a straight cut with a dull blade. Also, you can dull a blade fast by bouncing it off the stops. I guess they aren't designed for cutting steel.![]()
Then again, you've sawn more this year than I have in my life; so I appreciate your comment. I do have a couple of boards which I use to center the pith; that backfired though when I had to saw around rot in the butt end.Sawing from the "top" end is the "right" way, many logs mill easier from that end.
Buy of rig up toe boards and learn how to "properly" use them, and you will become a better sawyer because of it.
SR
Yep, a very nice job!^^^^^
That's a nice building. I'll bet that pine sawed a bit easier than the hemlock, also.
i think that by sawing from the large end rather than the small end, I will get some short boards from each log which I have been tossing into the slab pile.
