John Deere 820 pitted hydraulic line
   / John Deere 820 pitted hydraulic line #1
2345joes
Member
Western Oregon
John Deere 820
I was surprised that that the pitted line was the one with the leak (not the patched one). Is it typical to see this much foaming for a line leak?
   / John Deere 820 pitted hydraulic line #2
Water in the reservoir?
   / John Deere 820 pitted hydraulic line #3
Ditto on water in hyd oil. Water in hyd system is very detrimental to tractors brake linings. I recommend checking/cleaning trans oil screen when hyd oil is changed.
Would one check by opening the drain plugs to see if there is water at the bottom of the case? The hydraulic fluid was changed spring 2021.
   / John Deere 820 pitted hydraulic line #5
One is not surprised the 'pitted' line is leaking. It looks like a colander waiting to happen.
One would replace the pipework... drain all the oil possible... Change the filters... Clean the screens... Operate all rams and steering....
Repeat the above...
Cheak and repeat as often as necessary until clear oil is observed.
   / John Deere 820 pitted hydraulic line #6
Some types of hyd oil won't allow moisture to separate from the oil when oil is cool.
You can put a small amount of your tractors hyd oil in your wife's skillet then place skillet on her cook stove & turn on the heat. If hyd oil crackles when heated it contains H20. I suggest to perform this test while your wife is away from home!
I suggest to check condition of trans shifter boots & be sure breather in hyd oil filler cap behind seat isn't clogged.
   / John Deere 820 pitted hydraulic line #7
Looks to me like the unit has spent a hard life sitting out in the weather with minimal care. Replace the lines and get better with taking care of it, like changing fluids more often, filters too. Learned long ago, the better you take care of your equipment, the better it takes care of you.
   / John Deere 820 pitted hydraulic line #8
Looks like it just got it's first washing.
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
20ft Shipping Container (A51573)
20ft Shipping...
