Kubota Rear Inner Wheels Cracked
   / Kubota Rear Inner Wheels Cracked #11
I had a b8200 and the front wheels cracked like this. I just welded the cracks and put many more hours on it.
   / Kubota Rear Inner Wheels Cracked #12
I believe Titan made the wheels for Kubota. I agree with Hay Dude, cast center wheels are the way to go. Both mine came with cast centers and with the cast centers, the lug nuts are actually shouldered with a short cylindrical piece that indexes on the hole on the cast center. Never had issue one with either of mine. My fronts are still stamped steel but the mounting holes are chamfered and the lug nuts have tapered shoulders.
Nice thing about cast centers is no ballast liquid needed. The centers weigh about 400 pounds each.
I do check the prevailing torque on the fronts infrequently. Just like automotive wheels, they can back off.
Kubota wheels index on the raised hubs but when mounting you still need to have the wheels off the ground and wiggle them a bit to insure they seat on the wheel studs properly.
Far as JD goes, they mount the same way as Kubota.
   / Kubota Rear Inner Wheels Cracked #14
Seems like a material issue
Weld and grind or replace and hope I guess
   / Kubota Rear Inner Wheels Cracked #15
No, it was assembled in Moline, Illinois from parts sourced worldwide, so you are incorrect as well.
True, but then we'd have to also question Kubota's "made in Japan", as both are assembled in one place from components sourced worldwide. Put otherwise, if I make dinner in my kitchen from ingredients grown in another state, I still call it home cooking.
Not a big deal either way, both are good machines. Sorry if my attempt at humor was misinterpreted.
   / Kubota Rear Inner Wheels Cracked #17
Filled tires dont effect the stress on the rim beyond what added traction there is. And if they werent designed to be filled with fluid, they wouldnt come with two-piece air/liquid valve stems made for loading them.
I’m not gonna argue with you, but the long term stress of filled tires versus air filled tires is greater. Everything is carrying more load.
What I am thinking is Kubota may have under speced the steel in the rims, even unwittingly.
I have seen those cracks on many a Kubota.
Just spec cast rims and be done with all the filled tire nonsense and mess and extra wear (in my opinion). ;)
   / Kubota Rear Inner Wheels Cracked #18
It's a tractor not a race car so I wouldnt hesitate to weld the cracks for a second. If they continue to come back I would either weld thick washers over the holes or get a flange cut with the correct bolt pattern.
   / Kubota Rear Inner Wheels Cracked #19
Think I would have more confidence in welding a extra support plate to the original disk than a new replacement disk. Now those cast centers sound nice.
Kubota doesn’t recommend liquid ballast with a backhoe. They don’t say why. Even recommend ballast for 3pt hitch equipment but don’t tell you to remove the ballast to connect to a backhoe. Kubota kunfusion.
Hill county almost all tractors have liquid ballast. My Kubota TLBs have liquid ballast.
   / Kubota Rear Inner Wheels Cracked #20
I have 2 Kubota l3130 tractors and have cracked the rims on the one that I run tire chains on but not the one without tire chains
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2013 John Deere 824K (A53472)
2013 John Deere...
12in Backhoe Bucket (A53472)
12in Backhoe...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
JOHN DEERE 4730 LOT NUMBER 256 (A53084)
JOHN DEERE 4730...
New Long Forks (A53002)
New Long Forks...
