Long Term Diesel Storage with Mr. Funnel 5GPM F8C
   / Long Term Diesel Storage with Mr. Funnel 5GPM F8C #1
alylea
CT
JD LX280
Hi All,
So I have a 50 gallon diamond plate aluminum tank that I use for long term diesel storage for a generator. Fuel is rarely disturbed and tank is sealed with a pressure release cap. I treat it regularly with Power Service Diesel Treat + Cetane Boost, PS Clear Diesel, and PS Biocide. Tank is stored outside but not in direct sun. Outlet side runs through a water trap filter. I was thinking of getting a Mr. Funnel and recirculating the entire tank a couple of time through it grab any water that might have condensed out, and also grab any sludge that may have accumulated in the bottom. I will use a Jabsco pump with a dip tube to the bottom and a hose to the top for the recirculation.
Comments? Thoughts?
Lyle
   / Long Term Diesel Storage with Mr. Funnel 5GPM F8C #2
Hi All,
Comments? Thoughts?
Lyle View attachment 767268
It will be slow, but can’t hurt anything.
Hi jyoutz,
Thanks for the response. Figured I would let it run for about 30 minutes which should circulate the tank roughly 2.5 to 3 times while I did maintenance on the generator. Any other suggestions without it costing big $$$'s? Just looking to minimize the risk of bad fuel.
Lyle
   / Long Term Diesel Storage with Mr. Funnel 5GPM F8C #4
Hi jyoutz,
Lyle
IDK. Maybe putting it under a shelter would reduce condensation?
   / Long Term Diesel Storage with Mr. Funnel 5GPM F8C #5
I probably wouldn’t mess with it. Do you have anything that burns diesel other than the generator? If not maybe a neighbor with a tractor or truck that you could discount it to and burn it up. It’s been discussed before how long diesel lasts. I think in good conditions it’s years but I think after 2 or 3 years I’d want to burn it up and start fresh.
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2017 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2017 VOLVO VNL...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
Rubbermaid Water Trough - 100 Gallons (A55218)
Rubbermaid Water...
